4 members (Otto Skorzeny, WICruiser, dwreills, 78buckshot), 45 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#448758 09/04/2008 12:55 AM
I have a 59 Apache and am thinking about installing a Tremec TKO in it and was wondering where the shifter location would be compared to the stock 4 speed? Thanks
Denny Graham #449216 09/05/2008 5:43 AM
Not sure, but I think they don't offer anything far forward as the SM420. All are going to move the shifter back.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #449222 09/05/2008 5:52 AM
The center of the shifter for the sm420 is aproximately 4 1/2 inches from the transmission/ bellhousing mounting surface. I couldn't find anything on where those 8 different shifting locations were.
It looks like I can get the shifter at these locations (from bell housing)
7" Front shift
12.65" Mid shift (recommended for trucks)
A Muncie would be 16.75" (years ago I had a muncie in a 59 and it was real close to the seat when shifting)
Which location does everyone think will work the best with a bench seat?
tmcoors #449523 09/06/2008 3:19 AM
Well, the further forward the better, however I believe the 7 or 12.65 locations would work. The shifter on my 59 gmc is about 12 inches back from the bellhousing. I am using an NV4500. We may be discussing apples and oranges here because the bellhousing of a gmc v8 truck is further forward than a chevy's bellhousing. Safest bet is to get the shift location as close to stock as possible. Seems like the front shift would move you back 2 and 1/2 inches.
Here's the tech info on the tremec. In theory, there are three mounting positions for the shift linkage, but I've been told that they don't make the most forward adapter any more and it's $300 to get the middle one installed.
http://www.classicchevy5speed.com/TKO-Details.aspx
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
