7 members (Gdads51, moparguy, SNOYL, Hush, Gray_Ghost, Bill Hanlon, 1 invisible), 189 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
#44923 02/23/2005 2:24 AM
Junior Member
Junior Member
What is the correct number of ball bearings to put in the ball nut of a '50 1/2 ton steering gear? The Chevrolet Truck Shop Manual (1948-51) recommends 30 balls in each of the two circuits, which includes the balls within the two ball guides. However, after installing 60 balls (9/32 in dia.), I could see spaces between the balls when I turned the ball nut and looked between the two halves of each ball guide. To experiment, I was able to add 10 more balls, which I think completely filled both circuits and which did not seen to affect the functioning of the ball nut. I am tempted to continue with the rebuild of the steering gear, but first I would welcome and appreciate some input for the brain pool on this board.
#44924 02/23/2005 4:06 AM
I had this mess before too, on a GM Saginaw box. I seem to remember adding extra balls, only to have them bind up and jam. Verify correct ball size and number, and go with that. Any extra space may be to prevent jamming up. Been too long, I don't really remember.
Not much of an answer, huh?.......... :confused:
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#44925 02/23/2005 8:28 AM
At first, I was gonna answer..."Two!". :p
No really, I'm getting the service manual for my truck as soon as the guy I bought it from sends it to me. If you don't have an answer by then, I'll try to look it up.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#44926 02/28/2005 6:41 AM
yeah, "two".
#44927 03/02/2005 6:28 AM
i vote for 2. i do this to avoid ball bindup, which i hear is worse than the heartbreak of psoriasis. correct spacing is also important, as well as correct position. you should avoid getting your balls in a bind, and keep them well lubricated.
that said.
messing with a steering box without a good service manual is potential suicide. remember tolerances are crutial, and should you make a mistake, failure of the box could cause a horrendous accident.
please take your time, avoid experiments, and wait until one of these guys come up with the correct number of "bearings" and installation procedure. as i remember there are torque values which i would follow to the letter. there are also clearance issues that if not respected, will cause unexpected failure of the worm gear.
the old engineers were pretty smart, and in the case of something as critical as a steering box, their wisdom ought to be respected. if not, you could lose yer balls. eek
#44928 03/03/2005 3:11 AM
Koolcar,
are you saying that middle aged Engineers are not as smart? I used to enjoy your posts!! Only kidding, of course.
1951 1 Ton Completed
