0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
My local Harbor Freight sells Norton Rapid Strip discs to fit their 7" sander-polishers. The price was right, so I tried one out. Boy, do they work great! I stripped a set of window sashes that had 100 years worth of gummy house paint on them. It stripped the paint right off without loading up or hurting the wood underneath. I'm sold. I had been hitting them with a heat gun and scraping them and it took an hour to do each one. I did it in less than 10 minutes with the disc and I was being careful. The disc didn't seem to lose much abrasive in the process. Looks like it would be good to strip a truck with, I'm trying that next.
Buy the 7" variable speed grinder/polisher and one of these discs from Harbor Freight and you have a very good solution for about $50.
Paint & Body Shop moderator
4on the floor,
How does it mount? 5/8 left hand thread bolt? or other?
Brad
Hey 4, gotta picture?
Searching HF for Norton Rapid Strip gets no results.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
It mounts with the 5/8 thread, just like a wire cup would. It's not found on the HF web site, it may just be a local store item.
http://www.nortonconsumer.com/Media/Documents/S0000000000000001032/04013%207in%20Rapid%20Strip.jpg
It's about $15 normally, they had them on sale for $11.99 at the store but they sold out of them fast.
Thanks for the pic..I found a version made for a Makita sander today and bought it(on line). You needed a special attachment to mount the disk to which I wish wasn't needed but I'm looking forward to trying it with some decent rev's. I have two doors to strip..$225-$250 around here..so I'm open to elbow grease at this point in the season..This looks good. I'll also pick up the 7" if I can find one. Thanks.
keith
Those look like the same disks that come with the Wagner Paint Eater which I bought, use and recommend. Those disks will cut through paint like nothing and not remove any metal.
I've gotten a lot of flak for so much as mentioning these things but gradually, over time even the old timers will come around.
They really are THAT good.
As an aside, I went to the Norton website and will be awarding them the prestigious "STUPIDEST WEBSITE OF THE WEEK AWARD" Don't these morons want to SELL anything? UGH!
Woody
Door Art Collection
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97627
Is this what you are referring to???
found them in 40, 60,80 grit
Brad
4ONTHEFLOOR has posted a picture of the disc.
We call them scourer discs......and yes, they work a treat!
The one you have pictured is a Flap Disc.
These are no where near as effective in stripping paint, more suited to metal finishing.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
You can get them at a auto paint store that sells to body shops. The ones that brsdb3381 is refering to are used in fabracating steel and used to smooth down welds after welding.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Thank you both for the clarification. I searched "Norton" on the HF site & thats what came up, and was not sure about it.
Thanks again
Brad
After reading this thread at work I ordered some online..I actually bought the 3M equivalent-5" for my Makita disc sander..Just tried it..works great..instantly takes multiple layers of paint where ever it touches..as well as bondo that you didn't know you had...Leaves a burnished look but still has a tooth for good paint adheasion. This is a keeper..
Thanks for the tip..
Keith
The Home Depots around here carry the 4 1/2" version with the 5/8" thread. They work great and it's more convenient to just run to HD when one is needed vs ordering online.
"If you're not first, you're last". Ricky Bobby
1944 Chevy Firetruck
Halloween Decorations
1966 F**d Firetruck
here's the whole family:
http://www.ind.nortonabrasives.com/...0001035/Rapid%20Strip%20Flyer%207598.pdf
I don't think they sell from here thou
Keith
Moderated by  MNSmith
