0 members (), 311 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
PDM
Offline
Late 1953 6100
Late 1953 6100
Any advice on how to sneak a camshaft past rusted into their bores lifters? This is my first engine tear down and the pistons(aluminum) and steel lifters are stuck! I can rotate/force the cam with a wrench on the flats.
I have ATF soaking the pistons and lifters from the oil pan side but I would like to get the cam out of the way.
Thanks Pete
Upside down, beat them out w/long skinny screwdriver or punch. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I've had better success with PBBlaster or Kroil than ATF.
Can you get a pair of vise-grips on the lifters? You can get them to turn to break them free. Also, if you have a big enough torch heat the block, but not the lifter. The expansion might help.
Fred
52 3600
69 C-10
Soak them with Kroil for a few days, then drive them out from the bottom with a long punch. If you manage to move the lifters up about 1/8" or so, the cam should slide out under them, then you'll have more room to manipulate the lifters. If it's that tight, both the cam and lifters will be junk. Be careful and don't crack the block while you're removing the lifters!
PDM
Offline
Late 1953 6100
Late 1953 6100
used an old hammer handle as a drift
anyone got a spare thrust plate for the cam? frown
