6 members (Bill Trotter, 1955 1 Series, Otto Skorzeny, dt235sd, Jims46, Gray_Ghost), 121 guests, and 1 robot.
Topics128,193
Posts1,057,367
Members48,469
On my 46 1/2 t the gas gauge just reads up to 1/2 tank even when full. Any ideas as to why? I bought the truck as a 12 volt system, but I haven't found any additional add ons to the fuel wires (resisters or such).
Rick....
I had the same problem with my 46, I found that my float was corroded so I replaced it with whole new unit that seemed to fix the problem.
Ed
If the sender is a new unit, it may need to be adjusted by bending the float arm to read correctly. Or there may interference between the pickup and the float arm.
dg
Maybe you have a newer-rated sender and it is not matched properly with the gauge?
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=446291#Post446291
