1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | On my 46 1/2 t the gas gauge just reads up to 1/2 tank even when full. Any ideas as to why? I bought the truck as a 12 volt system, but I haven't found any additional add ons to the fuel wires (resisters or such).
Rick.... | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I had the same problem with my 46, I found that my float was corroded so I replaced it with whole new unit that seemed to fix the problem.
Ed | | | | | Joined: Oct 2007 Posts: 84 New Guy | | New Guy Joined: Oct 2007 Posts: 84 | If the sender is a new unit, it may need to be adjusted by bending the float arm to read correctly. Or there may interference between the pickup and the float arm. dg | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
