| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | So, the 235 has a steel tube from the oil pump to the block, which feeds the oil at pressure into everywhere. This is the line down under the oilpan, about 1/2" diameter.
I need a new one. Doesn't seem to be a common item. I can find copper tubing the right diameter, but the old pipe was steel. I'm afraid if I use copper, it will crack or split eventually, and ruin the motor.
I've got the fittings. Any idea where to get 1/2" steel tubing? I only need 6-8"
George 53 3600 | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | George, I had the same problem with my sump line on the 216 and I ended up buying a good used one on ebay. Where did you get those fittings ? I was able to buy the line NOS from , I think it was Antique Chev Parts (I will check) but I couldn't get the fittings. | | |
