9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible), 243 guests, and 1 robot.
Topics128,095
Posts1,056,075
Members48,433
I
I Offline
Just got my T5 and was wondering if anyone has a template to mount the e-brake. I figured I can fabricate something but it would be great if someone has already figured out the dimensions.
This is in a 47 1st, I have Buffalo Engineering's modified bell housing to keep the original clutch/brake pedal mount point.
I think I still have the one I used on my 46. Let me check on it tonight and I'll let you know.
George
would you mind letting me know too lol thanks
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
what is buffalo engineering's web site
1938 Gmc 1/2 ton
Well I found my template. Shoot me an email with your address and I'll send you a cardboard copy.
What I did was make a sample from 1/4" MDF that you can actually bolt to your trans to make sure it works before you make one out of 1/4" aluminum. You will also need to drill and tap two holes in your adaptor plate and make a "L" bracket for the rear mounting point.
Be sure to check out the links. Steppenwood has some good pictures of the process.
George
[email protected]
I
I Offline
Thanks George, sent you an e-mail with my address
TheShoer - Buffalo's site is http://inliners.org/buffalo
