6 members (TexasA&M48Truck, Charles in CA, MickeyP, Nick in Manitou, Ponchogl, 55shaker), 125 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#448440 09/03/2008 2:05 AM
1950 Chevy 3100. I had to replace the headlamp junction terminals on the inner fenders of my pickup. There was a 3 and a 4 post terminal. Though the catalogs show one each for that pick up, I can't get the 4 post to line up with the old holes. It looks as though the 3 post would fit either side. I checked the wiring diagram and it only shows 3 posts being used on either side. Is it supposed to have a 4 post or a 3 post and if it is a 4 post how is it supposed to fit? The old 4 post was pretty warped but I just thought it was age. Is it supposed to bend to make it fit?
nice work on your truck eric
Jim & Caroline
Your truck originally had the 3 terminal type hence the spacing. I wanted 4 terminals so I could add turn signals and solved it by making adapters out of strips of 1/2" x 1/8" aluminum that had 2 studs to go thru the inner fender and 2 tapped holes to mount the terminal block. I don't have a picture but they're nearly invisible anyways.
You Tube
