| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Just got my T5 and was wondering if anyone has a template to mount the e-brake. I figured I can fabricate something but it would be great if someone has already figured out the dimensions.
This is in a 47 1st, I have Buffalo Engineering's modified bell housing to keep the original clutch/brake pedal mount point.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I think I still have the one I used on my 46. Let me check on it tonight and I'll let you know. George | | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | would you mind letting me know too lol thanks
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | what is buffalo engineering's web site
1938 Gmc 1/2 ton
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Well I found my template. Shoot me an email with your address and I'll send you a cardboard copy. What I did was make a sample from 1/4" MDF that you can actually bolt to your trans to make sure it works before you make one out of 1/4" aluminum. You will also need to drill and tap two holes in your adaptor plate and make a "L" bracket for the rear mounting point. Be sure to check out the links. Steppenwood has some good pictures of the process. George [email protected] | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Thanks George, sent you an e-mail with my address TheShoer - Buffalo's site is http://inliners.org/buffalo | | |
