2 members (78buckshot, IHPWR), 88 guests, and 1 robot.
Topics128,024
Posts1,055,395
Members48,422
#448258 09/02/2008 5:57 PM
V
V Offline
What would I have to do to put a 3spd in and take the 4spd out? Its a 1948 1/2 ton. Or maybe put in an auto? Eng. is still 216.
Thanks Virg
virg912iowa #448264 09/02/2008 6:10 PM
I made the swap from 4 speed to 3 speed in a AD years ago. It is simle if you have a doner truck as you will need all the linkage including the steering gear mast jacket, to do it right.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #448302 09/02/2008 7:46 PM
V
V Offline
I was thinking to go with just a floor shift. Would the tranny just bolt up to the eng.?
Virg
virg912iowa #448344 09/02/2008 10:01 PM
Riding in the Passing Lane
The trans will bolt up but I wonder why you want to change. The 4 speed is a better trans. & 2nd gear is syncronized which you will use for a first anyway. They are not hard to o-haul if it has a problem & the final drive on the highway is the same.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #448395 09/03/2008 12:43 AM
You will need a new floor cover without a shifter doghouse in it. You will also need to change the U-Joint on the drive shaft if you are keeping the original rear end. It will bolt right up on the engine side. I believe there is a pin on the bellhousing on some of the 3 speed trucks that is missing on 4 speed trucks.
Paint & Body Shop moderator
My thoughts exactly... all that work for what?
The SM420 is a rock crusher, a fully sychro 3-speed with an extra low gear for the three times in the next 10 years that you may actually need it... but it's there if you do.
What's the point?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #448548 09/03/2008 12:38 PM
V
V Offline
I guess that about settels it,,,I keep the 4spd smile
Virg
