| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | If you order parts such as fenders that come painted, do you need to strip them before painting or can you paint over the paint on them? whar is the prefered method? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | It is probably primer and you sand and prep them like you would your own primer. I think it would be a mess if you would try to strip the primer. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Go over them real good with a green Scotch pad to break the shine and then put a coat of primer over that and then paint. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Most replacement sheet metal parts come with this coating. Here is information about the coating "EDP= Electro-deposit primer, which is a method of attaching primer to bare steel by electrically charging it. This process has been tested in 500 hours of salt spray with no corrosive effects. The only surface preparation required is scuffing of surface for better paint adhesion before painting. These parts are protected from rust as long as EDP coating remains under the paint." | | | | | Joined: Aug 2008 Posts: 5 New Guy | | New Guy Joined: Aug 2008 Posts: 5 | If the coating is black, it is most likely an Electrodeposition Coating (otherwise known as E-Coat). Scuff with a red scotch-brite pad, seal, and you're ready for paint. | | |
