2 members (Ponchogl, Gdads51), 98 guests, and 3 robots.
Topics128,128
Posts1,056,670
Members48,450
#426732 06/26/2008 2:04 AM
If you order parts such as fenders that come painted, do you need to strip them before painting or can you paint over the paint on them? whar is the prefered method?
It is probably primer and you sand and prep them like you would your own primer. I think it would be a mess if you would try to strip the primer.
Go over them real good with a green Scotch pad to break the shine and then put a coat of primer over that and then paint.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Most replacement sheet metal parts come with this coating. Here is information about the coating "EDP= Electro-deposit primer, which is a method of attaching primer to bare steel by electrically charging it. This process has been tested in 500 hours of salt spray with no corrosive effects. The only surface preparation required is scuffing of surface for better paint adhesion before painting. These parts are protected from rust as long as EDP coating remains under the paint."
If the coating is black, it is most likely an Electrodeposition Coating (otherwise known as E-Coat). Scuff with a red scotch-brite pad, seal, and you're ready for paint.
