2 members (55shaker, Paul_WNC),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44834 11/29/2004 6:41 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | My Carter W-1 is missing the triangular brass tag. Can anyone tell me what the tag number is for this crab? Thanks!
I should mention this is for a 1948 216 engine.
1948 3600 thriftmaster
#44835 11/29/2004 7:50 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | The original carburetor would have been a 574s. Quite frequently, one finds an incorrect carburetor on an engine.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#44836 11/29/2004 10:16 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | Thanks Carbking, I think I need a rebuild because my truck bogs down and stalls when I accelerate unless I have the choke pulled out half way, any thoughts on this?
#44837 11/29/2004 10:41 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Normally when one has to have the choke pulled, either the carburetor has stopped up passages, or the fuel delivery system is not keeping the carburetor full of fuel. I would suggest checking the fuel delivery system. If that checks out OK, then a carburetor rebuild is probably in your future.
#44838 11/29/2004 11:32 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | Thanks carbking, I figured as much. Is there any reason I should avoid running the engine with the choke pulled half way? I probably won't be able to get it rebuilt for a couple weeks, and I don't want to do further damage to anything.
#44839 11/30/2004 12:18 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Maybe one of the engine gurus will jump in and answer your last question.
