1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#44834 11/29/2004 6:41 PM
My Carter W-1 is missing the triangular brass tag. Can anyone tell me what the tag number is for this crab? Thanks!
I should mention this is for a 1948 216 engine.
1948 3600 thriftmaster
#44835 11/29/2004 7:50 PM
Carburetion specialist
The original carburetor would have been a 574s. Quite frequently, one finds an incorrect carburetor on an engine.
Jon.
The Carburetor Shop
#44836 11/29/2004 10:16 PM
Thanks Carbking, I think I need a rebuild because my truck bogs down and stalls when I accelerate unless I have the choke pulled out half way, any thoughts on this?
#44837 11/29/2004 10:41 PM
Normally when one has to have the choke pulled, either the carburetor has stopped up passages, or the fuel delivery system is not keeping the carburetor full of fuel. I would suggest checking the fuel delivery system. If that checks out OK, then a carburetor rebuild is probably in your future.
Jon.
The Carburetor Shop
#44838 11/29/2004 11:32 PM
Thanks carbking, I figured as much. Is there any reason I should avoid running the engine with the choke pulled half way? I probably won't be able to get it rebuilt for a couple weeks, and I don't want to do further damage to anything.
#44839 11/30/2004 12:18 AM
Maybe one of the engine gurus will jump in and answer your last question.
Jon.
The Carburetor Shop
