2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#448171 09/02/2008 2:24 PM
I've got a 1946 chevy pickup that I am disassembling to restore.I. I have the windwhield and top trim off. I just need to know how to take the dashboard out.I took out the screws on the top It (They were so rusted I ended up chiseling them off)I know there is probably more much more holding it.Can anyone help?
If you have all the screws out under the windshield area ( I think there are about 6 ? ), there is ( 1 ) bolt at each side of the lower inside corner. The upper lip of the dash slides over the lip of the lower windshield opening. It may be rusted in there - needs some gentle persuasion.
1940 Chevy KC 1/2-Ton
There is six screws on the top underneath windshield to remove, windshield regulator needs removed, steering wheel brace and a bolt on each side at the bottom. Tilt the dash out at the bottom and lift up as it has a lip that fits over the windshield area. There is a center of dash brace also. Mine came out pretty easy. Good luck and have fun.
Dan
First of all thanks to everyone for the great info. Does anyone know how to remove the steering wheel brace?
Moderated by  ndkid275, Phak1
