| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | LETS SEE THEM!!! For both Advanced Design and Task Force trucks. What did you get it out of and how easy/hard was it to adapt to these trucks.
I like the look of those aftermarket tilt columns but not the price. I live with in miles of a large U-Pull-It yard that has thousands of cars and trucks of every make, mainly 80's to late 90's/early 2000's. I went today looking at what could be used and seen a few that may work, but would like to see what everyone else is using in their trucks. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I used a column out of 89 S-10 Blazer with tilt. Really steering columns are real easy to fabricate. If you can't find a short one out of a 70's chevy van, you can shorten just about anything. All you need is a couple of universal joints and line it up. When I stubbed my truck with a Nova subframe I just cut a new hole in the floor to line up the steering gear and column. I plan on using the turn signal and ignition on the new column. | | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | used 89 astro column (tilt) | | |
