1 members (Ponchogl), 142 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
I
I Offline
New guy to the site so I'll start by saying love the site, alot of good info and pictures. I have a chance to by a 46 chevy but not sure of the tonnage. There is a metal tag on the drivers side running board that reads "16000 gross". It has an Inline 6, so being a bigger truck would that be the 235? And where would the numbers be so I could check. Thanks for the help.
16000lb. gvw, would denote a 2 ton. A 1 1/2 ton, would be 14000lb. gvw. Being in the place you noted, doesn't sound like the manufacturer ID plate. On the '46, I had, the ID plate was under the hood, to the passenger side of the cowl. Check for this tag, for proper identification. Maybe someone on here can post a picture of the location for you. Welcome to The Stovebolt Page.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Big Bolt Forum Co-moderator
Well the 1600 gvw would indicate a 2 ton as far as I know. You can tell the engine ID if you look on the block. The serial number is stamped on a flange just in front of the distributor.
The link below will get you to the tech tip on engine ID
http://www.stovebolt.com/techtips/engine_identification.htm
1948 Chevy 2-Ton
I
I Offline
There is a tag on the passenger side. I'll see if I can even read it. So being a 2 ton would the cab, fenders and hood be the same size as the 1 1/2 ton or bigger. I know the 1/2 ton and 1 1/2 ton are interchangable, but the 2 ton looks bigger to me.
Fenders are the only thing that don't swap out on your list above. They will bolt up, but the wheel openings are of course larger on the big trucks...
Is that right? The 1/2 ton and the 1 1/2 ton fenders are interchangeable? I would of thought that the 1 1/2 and 2 ton fenders would be interchangeable if anything.
1948 Chevy 2-Ton
And I thought in 46 the largest Chevy made was a 1.5 ton?? Am I confused with a different year?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
chevy made a conventional 2 ton in 46 ive got one. im pretty
sure the sheet metal is the same as a 1.5 ton . the main difference
is the rear springs, reinforcement plates on the chassis and things
like hydrovac as standard equipment.
Grigg - 46 was the first year for higher ton-rating models, meaning some difference in frames, and in 46 it was adding a long gusset plate outside the frame rail, as Philip sez .... there was always a range of GVW ratings in any nominal ton rated model, achieved by increasing springs and tires
