| | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 4 New Guy | | New Guy Joined: Aug 2008 Posts: 4 | New guy to the site so I'll start by saying love the site, alot of good info and pictures. I have a chance to by a 46 chevy but not sure of the tonnage. There is a metal tag on the drivers side running board that reads "16000 gross". It has an Inline 6, so being a bigger truck would that be the 235? And where would the numbers be so I could check. Thanks for the help. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 16000lb. gvw, would denote a 2 ton. A 1 1/2 ton, would be 14000lb. gvw. Being in the place you noted, doesn't sound like the manufacturer ID plate. On the '46, I had, the ID plate was under the hood, to the passenger side of the cowl. Check for this tag, for proper identification. Maybe someone on here can post a picture of the location for you. Welcome to The Stovebolt Page. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Well the 1600 gvw would indicate a 2 ton as far as I know. You can tell the engine ID if you look on the block. The serial number is stamped on a flange just in front of the distributor. The link below will get you to the tech tip on engine ID http://www.stovebolt.com/techtips/engine_identification.htm A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2008 Posts: 4 New Guy | | New Guy Joined: Aug 2008 Posts: 4 | There is a tag on the passenger side. I'll see if I can even read it. So being a 2 ton would the cab, fenders and hood be the same size as the 1 1/2 ton or bigger. I know the 1/2 ton and 1 1/2 ton are interchangable, but the 2 ton looks bigger to me. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Fenders are the only thing that don't swap out on your list above. They will bolt up, but the wheel openings are of course larger on the big trucks... | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Is that right? The 1/2 ton and the 1 1/2 ton fenders are interchangeable? I would of thought that the 1 1/2 and 2 ton fenders would be interchangeable if anything. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | And I thought in 46 the largest Chevy made was a 1.5 ton?? Am I confused with a different year?
Grigg | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | chevy made a conventional 2 ton in 46 ive got one. im pretty sure the sheet metal is the same as a 1.5 ton . the main difference is the rear springs, reinforcement plates on the chassis and things like hydrovac as standard equipment. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Grigg - 46 was the first year for higher ton-rating models, meaning some difference in frames, and in 46 it was adding a long gusset plate outside the frame rail, as Philip sez .... there was always a range of GVW ratings in any nominal ton rated model, achieved by increasing springs and tires Bill | | |
