1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 1 New Guy | | New Guy Joined: Aug 2008 Posts: 1 | Hi, I just found a 1940 chevy 3/4 ton pickup. I want to update the suspention but Im not sure which way to go. I have a camaro front clip is that better than a mustang II ? I plan on intalling a chevy V8 in the truck. Thanks,
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Rico,
Since you are running a 3/4 ton, what are you planning on hauling? In reading the posts here, the MII front end is pretty light for doing much heavy work. The benefit that I see is the MII is easier.
Not sure if you have done so, but do a search on both. There is much to be read about on here for both. | | |
