1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | has anyone put a cab on a nova frame. and if you have what do you have to do. some street rodders told me they sent it or had done it, but its been a while since i talked about. at the time i didnt have no chevy to work with, now i got 2. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The Nova does not have a complete frame like your truck. It has a sub frame that bolts to the body just behind the firewall area. The Nova is a unibody car where the body and frame are one structural unit.
What the street rodders are referring to is using the sub frame from the Nova, and grafting it to your truck frame. Do a search for subframing and you will get some good results. Also look on Webrodder.com, there is a wealth of info there. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm thinking the '74 Nova is too wide. Unless you narrow the crossmember you'll have trouble getting the wheels to fit inside the front fenders. If you narrow the crossmember you'll have lots of other issues to contend with.
My advice is look for something different.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | The '74 Nova sub frame is not too wide. It will work fine. I put one in my '54 Chevy Panel. '69-'74' Nova and '67-'69 Camaro are the same width. The '70-81 Camaro and the '75-'79 Nova are 2'' wider than the earlier Rear steering box front ends. | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i heard it could be done, they use them a lot to make a rat rod, or street rod. they cut the bottom of the cab down and place it on the frame, but since then i found out the nova had severe cancer underneath. | | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | Wish I had noticed this post earlier. Just got a 1974 Nova subframe reinstalled on the Nova. Could have gotten a lot of measurements. Still could, I guess, if you need them.
Its sitting in the shop next to my '53 pickup project. | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | that would be wonderful. pictures 2 if you got some, thanks danny | | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | I'll see if I can work it in...busy time planting wheat right now. See if you can access the forum below, if you can, it has the Nova pics...the car belongs to my son. 74 Nova project, page 6 | | |
