4 members (cmayna, Jon G, greenie-reddy, 1 invisible), 302 guests, and 5 robots.
Topics128,268
Posts1,058,395
Members48,485
#447743 09/01/2008 3:57 AM
has anyone put a cab on a nova frame. and if you have what do you have to do. some street rodders told me they sent it or had done it, but its been a while since i talked about. at the time i didnt have no chevy to work with, now i got 2.
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
The Nova does not have a complete frame like your truck. It has a sub frame that bolts to the body just behind the firewall area. The Nova is a unibody car where the body and frame are one structural unit.
What the street rodders are referring to is using the sub frame from the Nova, and grafting it to your truck frame. Do a search for subframing and you will get some good results. Also look on Webrodder.com, there is a wealth of info there.
I'm thinking the '74 Nova is too wide. Unless you narrow the crossmember you'll have trouble getting the wheels to fit inside the front fenders. If you narrow the crossmember you'll have lots of other issues to contend with.
My advice is look for something different.
The '74 Nova sub frame is not too wide. It will work fine. I put one in my '54 Chevy Panel. '69-'74' Nova and '67-'69 Camaro are the same width. The '70-81 Camaro and the '75-'79 Nova are 2'' wider than the earlier Rear steering box front ends.
i heard it could be done, they use them a lot to make a rat rod, or street rod. they cut the bottom of the cab down and place it on the frame, but since then i found out the nova had severe cancer underneath.
Wish I had noticed this post earlier. Just got a 1974 Nova subframe reinstalled on the Nova. Could have gotten a lot of measurements. Still could, I guess, if you need them.
Its sitting in the shop next to my '53 pickup project.
that would be wonderful. pictures 2 if you got some, thanks danny
I'll see if I can work it in...busy time planting wheat right now. See if you can access the forum below, if you can, it has the Nova pics...the car belongs to my son.
74 Nova project, page 6
