| | | Forums66 Topics128,115 Posts1,056,623 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | got no book, whats the best way to start removing the fenders from the truck, later the cab, where are the bolts located. before i get started. got 2 projects going at one time. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Front fenders and fender braces are bolted to the cab. The radiator support bolts to the front cross member. The fenders , inner fenders and grille all come off in one piece. I like to rake the radiator out and take the fan off and then just kind of roll the whole thing forward. The back of the cab is mounted with shackles and the bolts in front will now be exposed. | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i just got the truck and the front grill and assy that holds the hood down is out, raditor is also out. roll the whole thing out what does that consist of , i mean remove how many or which bolts. thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Get the book. The best way to start is to take pictures. If you can't figure out how to get it apart, you'll never get it back together without the book and pictures. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Get the book. The best way to start is to take pictures. If you can't figure out how to get it apart, you'll never get it back together without the book and pictures. I never thought of it in that respect, but taking things apart have never really been a problem, but I have had some challenges in putting them back together. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Are you supposed to put them back together? Maybe that's what I've been doing wrong all these years!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | got no book, what it wasnt bad. me underneath, friend underhood. about 2 hours and the complete front section was removed. thanks danny | | |
