0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44739 03/12/2004 6:53 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | Hi guys, new to the board, but I've been reading and gaining knowledge from this board for about a year. It's great!
I finally registered because I have two questions. I just had my 250 rebuilt and I'm in the process of reinstalling it. My questions have to do with installing the clutch. Of course in my rush to get the engine to the shop, I pulled of the clutch without noting anything.
Q#1: On the throwout bearing, there is a raised hump in the outside groove. Does this hump go between the fork fingers or outside of the fork fingers?
Q#2: The new clutch set came with a sleeve or bearing about 3/4" long, funny, when I took off the old clutch this part was and is no where to be found. Do I install it? or was it made for a different model? where does it go?
Any help would be appreciated. Dano
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#44740 03/12/2004 7:49 PM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | Not quite sure I understand the first question--do you have any pics? The reason you didn't see that brass bushing when you took the clutch apart is because it's located in the back of the crankshaft. The nose of the transmission rides inside this bushing, to keep it lined up with the engine during accleration, etc. I guess if you had a new crank put in, you won't have to worry about getting the old one out--just drive the new one in. Do you already have the motor in the truck? If so, replacing this bushing will be a bit harder than if it is still on the stand. Several ideas on removing the old bushing: 1. pack the cavity full of grease, find a rod, pin, etc. close to the same size as the hole, drive the pin into the hole, and let the grease force the bushing out. If the motor is out of the truck, this might work, but I've never been able to do it in the truck. 2. get a pilot bearing puller, like this one from matco. 3. take a die grinder and grind the old one out, but just don't hit the crank! | | |
#44741 03/12/2004 8:56 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | The hump if I understand you correctly would go in the fork, it is used to keep that inside of the throw out bearing form turning.
One note about using the grease in the pilot bushing. If you go this route, please place a rag around the dowel rod so you don't spray grease everywhere one the bushing is free.
Good luck and welcome to the bolt!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#44742 03/12/2004 9:02 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#44743 03/13/2004 3:23 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Hey 6! That's too easy, it has to be cheating! (Why the heck didn't I think of that one?)
35 + years of rollin' steel!
#44744 03/13/2004 7:10 AM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | 6Cly, I can't resist asking what kind of tap you are going to use on a bearing? Those races are pretty hard This trick sure works great on bushings, though. Joe | | |
#44745 03/13/2004 12:49 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Instead of grease to pack the cavity, use wet toilet paper. Works just as well and cleanup is a lot easier. | | |
#44746 03/13/2004 5:55 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Joe Way, I called the pilot bushing a "bearing" only as a point of reference because big61fourby referred to it as a bearing when writing, "GET A PILOT BEARING PULLER, LIKE THIS ONE FROM MATCO."  I have never tried to use a tap to remove a bearing :confused: , might be able to be used on a small new plastic bearing holders :p , however, the point is, Joe Way, that a tap will do an excellent job of pulling a bushing :rolleyes: !
#44747 03/14/2004 12:22 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Chuckthetruck: If I understand you correctly your are RECYCLING your TOILET PAPER and using it to REMOVE PILOT BEARINGS? Gawd......I'm not about to ask what your doing with your old condoms. :rolleyes: | | |
#44748 03/15/2004 9:12 AM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | Thanks guys! Luckily the engine rebuilder must have removed the old bearing for me. I'm just having a hell of a time driving the new bearing in. It's midnite here on the left coast so I'll try again tomorrow morn.
Again thanks for the grease/TP/Tap solution on driving out them old bearings!
Dano
#44749 03/15/2004 2:37 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | try putting it in th efrezzer and then installing it.
#44750 03/16/2004 1:29 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Play doh is even better than grease or wet TP in the cleanup department. Just don't give it back to your kid when you are done.
