0 members (), 186 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#44724 07/24/2004 6:38 AM
I was just at a cruise night with my Pontiac and a guy told me he poured a small amount of auto trans fluid in his carburetor while engine was running. This was to help things seal/reseal. Anybody heard of this?
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#44725 07/24/2004 12:45 PM
Carburetion specialist
Obviously due to his second "job" as a mosquito eradicator.
I fail to see a benefit to either the carb or the engine.
Jon.
The Carburetor Shop
#44726 07/24/2004 12:59 PM
I was told that ATF can sometimes loosen sticking rings. I guess the shock!
Jim
#44727 07/24/2004 1:11 PM
I've known people to pour water in the carb of a warm, running motor to get rid of carbon. I will say that a boosted motor running W/I will have clean combustion chambers when it is torn down.
People will pour ATF in everything except a tranny to cure problems, but I myself have never seen it cure anything.
Larry
#44728 07/24/2004 9:31 PM
Remember when I was a young pup back in the 60's some of the old time mechanics used to say this would help seat rings and valves after a rebuild. Would smoke like the devil and would definitely clear the area.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#44729 07/25/2004 3:32 AM
I've done it!! I works! It frees sticky valves, and, removes carbon build up in the combustion chamber & intake valves. It works better if you pour it in while running, Then shut the engine down & let it sit overnight. Go for a good blast the next day. It's cured pinging problems for different applications for me in the past.
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#44730 07/25/2004 3:36 AM
You can also follow this up with trickling water down the carb when at around 2k rpm. The water creates "steam", and, cleans the combustion chamber up nice. Ever pull a head with a bad gasket?? The suspect cylinder is always spotless.
#44731 07/25/2004 4:23 AM
Yeah, this guy said it'll smoke like crazy but he swore his engine ran much better afterwards. So, it seems like mixed opinions here. I thought for sure Hotrod Lincoln would be the first to chime in here. Jerry, you out there?
My \'65 Chevy C-20
#44732 07/25/2004 4:44 AM
How much water and atf would you put in?
Jess smile
1951 3100
#44733 07/25/2004 3:15 PM
Riding in the Passing Lane
It,s also good to pour some in the carb with
engine running before shutting it down for a
long period. Coats every thing.
Where is hot-rod? He hasn,t jumped in lately.
1972 Chevy c10 Cheyenne Super
#44734 07/25/2004 3:42 PM
Y
Y Offline
Dont know how much ATF content is in it. But "Fogging Oil" does basically the same thing Wrenchbender has described. Comes in a spray can. Boating types spray it into the carb when laying up marine engines for a while. IMHO, the spray makes it easier to handle. Most auto part stores have it too.
#44735 07/25/2004 5:00 PM
GM sells "top engine cleaner" over the counter.
It's used the same way I described using the ATF.
Gm has a few service bulletins for different symptoms that outline this procedure. Symptoms range from engine miss, ping,to carbon knock. But, with the modern fuel injected engines, the cleaner is introduced/ingested through the pcv system. The water part is tricky. I don't feel comfortable describing it in print. It was something an oldtimer physically showed me. It's better to see it done in person. It does work well though.
#44736 07/25/2004 5:12 PM
A friend of mine told me about water in the carb. Said it'll absolutely clean out the carbon. He said with engine running and warmed up, use a spray bottle with a mist. He thought 1 spray maybe every 10-15 seconds for a few minutes did the trick.
My \'65 Chevy C-20
