1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44724 07/24/2004 6:38 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I was just at a cruise night with my Pontiac and a guy told me he poured a small amount of auto trans fluid in his carburetor while engine was running. This was to help things seal/reseal. Anybody heard of this? | | |
#44725 07/24/2004 12:45 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Obviously due to his second "job" as a mosquito eradicator.
I fail to see a benefit to either the carb or the engine.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#44726 07/24/2004 12:59 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | I was told that ATF can sometimes loosen sticking rings. I guess the shock!
Jim
#44727 07/24/2004 1:11 PM | Joined: Apr 2004 Posts: 36 Member | | Member Joined: Apr 2004 Posts: 36 | I've known people to pour water in the carb of a warm, running motor to get rid of carbon. I will say that a boosted motor running W/I will have clean combustion chambers when it is torn down.
People will pour ATF in everything except a tranny to cure problems, but I myself have never seen it cure anything.
Larry | | |
#44728 07/24/2004 9:31 PM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Remember when I was a young pup back in the 60's some of the old time mechanics used to say this would help seat rings and valves after a rebuild. Would smoke like the devil and would definitely clear the area.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
#44729 07/25/2004 3:32 AM | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | I've done it!! I works! It frees sticky valves, and, removes carbon build up in the combustion chamber & intake valves. It works better if you pour it in while running, Then shut the engine down & let it sit overnight. Go for a good blast the next day. It's cured pinging problems for different applications for me in the past. | | |
#44730 07/25/2004 3:36 AM | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | You can also follow this up with trickling water down the carb when at around 2k rpm. The water creates "steam", and, cleans the combustion chamber up nice. Ever pull a head with a bad gasket?? The suspect cylinder is always spotless. | | |
#44731 07/25/2004 4:23 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Yeah, this guy said it'll smoke like crazy but he swore his engine ran much better afterwards. So, it seems like mixed opinions here. I thought for sure Hotrod Lincoln would be the first to chime in here. Jerry, you out there? | | |
#44732 07/25/2004 4:44 AM | Joined: Jul 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 60 | How much water and atf would you put in? Jess
1951 3100
#44733 07/25/2004 3:15 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s also good to pour some in the carb with engine running before shutting it down for a long period. Coats every thing. Where is hot-rod? He hasn,t jumped in lately. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#44734 07/25/2004 3:42 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Dont know how much ATF content is in it. But "Fogging Oil" does basically the same thing Wrenchbender has described. Comes in a spray can. Boating types spray it into the carb when laying up marine engines for a while. IMHO, the spray makes it easier to handle. Most auto part stores have it too. | | |
#44735 07/25/2004 5:00 PM | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | GM sells "top engine cleaner" over the counter. It's used the same way I described using the ATF. Gm has a few service bulletins for different symptoms that outline this procedure. Symptoms range from engine miss, ping,to carbon knock. But, with the modern fuel injected engines, the cleaner is introduced/ingested through the pcv system. The water part is tricky. I don't feel comfortable describing it in print. It was something an oldtimer physically showed me. It's better to see it done in person. It does work well though. | | |
#44736 07/25/2004 5:12 PM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | A friend of mine told me about water in the carb. Said it'll absolutely clean out the carbon. He said with engine running and warmed up, use a spray bottle with a mist. He thought 1 spray maybe every 10-15 seconds for a few minutes did the trick. | | |
