Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#44712 10/07/2002 7:28 PM
hello I've found numbers on the block next to the distributor sure is alot of em can anyone help me determine what they mean?num.:03333867557 are there too many #'s there or is that right?I copied all #'s on the flat plate next to dist. thanks
#44713 10/08/2002 2:54 PM
Those numbers by the dist aren't the engine casting numbers. I think those are the VIN/Serial for the engine's original application. The engine casting numbers are on the pass side of the block, near the vent tube and fuel pump.
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#44714 10/10/2002 1:12 PM
If you have a 235, this number should begin with a letter.
The first letter is the plant (T = Tonowanda F = Flint, etc) the second is the month built (01 = Jan, 02 = Feb, etc) the third is the day (1-2-3-etc) then possibly another letter.
Or....
The letters should appear at the end of the sequence.
Could the last part of your number be "F 55.." and not 7 55?
