| | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44712 10/07/2002 7:28 PM | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | hello I've found numbers on the block next to the distributor sure is alot of em can anyone help me determine what they mean?num.:03333867557 are there too many #'s there or is that right?I copied all #'s on the flat plate next to dist. thanks | | |
#44713 10/08/2002 2:54 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Those numbers by the dist aren't the engine casting numbers. I think those are the VIN/Serial for the engine's original application. The engine casting numbers are on the pass side of the block, near the vent tube and fuel pump.
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#44714 10/10/2002 1:12 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | If you have a 235, this number should begin with a letter.
The first letter is the plant (T = Tonowanda F = Flint, etc) the second is the month built (01 = Jan, 02 = Feb, etc) the third is the day (1-2-3-etc) then possibly another letter.
Or....
The letters should appear at the end of the sequence.
Could the last part of your number be "F 55.." and not 7 55? | | |
