5 members (Leo, Gdads51, cmayna, ShopRag, moparguy), 114 guests, and 2 robots.
Topics128,113
Posts1,056,280
Members48,439
I have a guy at work who is just finishing up his 1952. He has the repro original style mirrors that appear to mount on the cowl. The right one being that strange snake looking one that apparently you see from thru the windshield instead of the door glass.
Could one of you post a photo of the placement of these mirrors? Measurements, something? smile
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
They are mounted through the holes that are visible from the inside sheet metal. On the driver's side you can see the two holes that need to be drilled through the cowl. On the passenger's side, the glove box blocks the view.
1951 1 Ton Completed
Tell him to look up under the cowl and he should see reinforcement pieces on each side that have the holes in them.
You Tube
I'll tell you what, I was so thrilled with this news I just ran out there to find that it doesn't make any sense at all when looking at it. The brackets appear to mount with the holes vertical, one hole over the other. While the trucks inner cowl has no provisions for holes in that way. They look like they were horizontal but one on each side have been welded up with a metal patch!
Also, the brackets look like they would both be right sides, though totally different in shape, they both look they could only go on the right side.
Know I know why I went with peep mirrors on my truck. smile
Brian
1948 Chevy Pickup
You're probably not looking in the right place. Crawl up under the dash on the driver side and look up at the inside portion of the cowl just above the inner cowl panel. You will see a second structural/reinforcement looking piece that extends from the door pillar almost to the firewall. That piece has been pre-drilled with two holes, in a vertical pattern.
Those holes are there specifically for one reason... to act as guides for drilling the holes in the cowl for those mirrors. Unless your friend's truck has suffered catastrophic damage, those pieces are there... and if I'm not mistaken the procedure for installing those mirrors is covered in the Assembly Manual.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Ok, I got under there and see that there is a mess there with holes filled with bondo and what not. I went home and looked at mine and see the same as in your photo.
So, I know where to drill the holes. Does anyone have a link to a good photo of these mirrors mounted on the truck. I swear it looks like I have two right sides. They are totally different with the "Correct" right one being that snake looking thing. But the straighter "left" one looks like it could only mount on the right side.
I have searched around on the net but never find a good clear picture. It doesn't need to be a close up or anything, just a decent picture of both sides of the truck with these original mirrors.
Brian
1948 Chevy Pickup
Here are some photos of the ones on my truck. I used the bigge mirrors but the arms are the same.
http://rides.webshots.com/album/563164758bpwzLP?start=24
Here's a pic of my '49 with the mirrors attached.
http://rides.webshots.com/photo/2639421800010188466rgInAn
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
Thanks so much guys, you are the greatest. Got it all figured out, I held them up there for him to see how they work and he says GREAT. I am thinking I may run those on my truck.
If I can find some original ones, I don't do repro.
Brian
1948 Chevy Pickup
Well, I put the mirrors on his truck, wham bam done, thanks so much. He took off before I could get a picture. I'll post one on Monday.
Thank you, and Francisco thanks you.
Brian
1948 Chevy Pickup
AAAAH POOP Brian!
I recently sold my stockers on E-Bay that were in great shape especially the lens ...dang sorry!
look there they come up time to time.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Bummer, I am going after the original look (original chopped and sectioned dream car sort of look smile ) and they may be the way I will go.
Brian
1948 Chevy Pickup
