| | | Forums66 Topics128,284 Posts1,058,525 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 20 Apprentice | | Apprentice Joined: Dec 2005 Posts: 20 | Howdy; quick question:I'm trying to adapt my '59 fuel guage to read with a later model GM sender.I have heard that a resistor can be added to the sender wire.Anyone know what resistor to use?TIA
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | First of all, you didn't state the value of the sender. I believe it is 0-90 ohms, but not sure. You can indeed pad the sender with a resistor in parallel but it will be nonlinear, meaning it may be correct are zero but only read 3/4 when tank is full.
| | | | | Joined: Dec 2005 Posts: 20 Apprentice | | Apprentice Joined: Dec 2005 Posts: 20 | From what I have read,all of the later gm senders are 0-90 ohm while the older gage is 0-30.I was hoping to be able to add a resistor in series on the sender wire.If that isn't possible,I will probably replace the gage rather than drop the tank.Thanks for any info. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you're working the wrong way round to add resistance, if it was a 90 ohm gauge and a 30 ohm sender you might make it work, but the 90 ohm sender won't work with an original [30 ohm] gauge, one or the other has to be changed | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | There is a ton of information on this problem if you do a search. Get a 0-100 ohm variable resistor, remove the sender wire from the gauge post, hook the variable res. to the gauge sender post and ground other side of resistor to gauge case. Turn key switch on, turn variable resistor until gauge reads empty. Turn key off, remove resistor and use ohmmeter to read its value. That ohm value is what your gauge wants to see for an m/t tank. Repeat above test for full tank, 1/2, 3/4, or whatever. For a 0-30 ohm gauge and a 0-90 ohm sender and do the math, you will find that putting a 47 ohm (a standard resistance value)in parallel with 90 ohms (full tank) will give a 30 ohm value to the gauge...great right. But then, when you reach 1/2 tank and the value to the gauge should be 15 ohms it instead will be 22 ohms which looks more like 3/4 tanks. WOW...I'm getting great gas milage with this new sender. Empty will be right on because of the zero resistance thingie, but when you get to 1/8 of a tank and start looking for a gas station, it had better be right up ahead. All-in-all its how you look at things. If you play horseshoes or throw hand grenades, then anything close counts. If you are a sniper...well, you understand. Good luck
| | | | | Joined: Feb 2000 Posts: 5,269 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,269 | | | | | | Joined: Dec 2005 Posts: 20 Apprentice | | Apprentice Joined: Dec 2005 Posts: 20 | thanks for the info guys.I did try searching the forums before posting,but couldn't find the specific info.looks like it's not as straight forward as I thought,I may just install an aftermarket gage with a 90 ohm value. | | |
