0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#44623 03/24/2003 1:03 PM
Finally got my '51 3100 frame done in POR-15, and am building up the frame components. Put on new brakes and E-brake cables. I have a two piece rod that connects between the pedal and the E-brake cross shaft. The assembly manual shows a single rod with a tab welded on it to hook on a spring. I have one spring and one wire extension about 8" long. No tab on the rod to hook spring to. I can't remember how this spring and extension were hooked to the frame and brake rod. I've tried to just look at the situation but still can't figger it out.. can anybody provide some guidence? Thanks!
#44624 03/24/2003 7:34 PM
Remember that assembly manual is for 1954 trucks, I think. On yours, that spring extension hooks to the midpoint of the connector rod, the spring on the other end hooks to the cross member, look close, you will see a hole near the edge.
#44625 03/25/2003 1:12 PM
Thanks Brian - I'll look closer for the spring attachment point this evening, maybe the POR-15 gooped over it..I didn't realize the manual is for a '54.
