7 members (51sub, WICruiser, greenie-reddy, NJC, Peggy M, Tronman, Gray_Ghost),
102
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44623 03/24/2003 1:03 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Finally got my '51 3100 frame done in POR-15, and am building up the frame components. Put on new brakes and E-brake cables. I have a two piece rod that connects between the pedal and the E-brake cross shaft. The assembly manual shows a single rod with a tab welded on it to hook on a spring. I have one spring and one wire extension about 8" long. No tab on the rod to hook spring to. I can't remember how this spring and extension were hooked to the frame and brake rod. I've tried to just look at the situation but still can't figger it out.. can anybody provide some guidence? Thanks! | | |
#44624 03/24/2003 7:34 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Remember that assembly manual is for 1954 trucks, I think. On yours, that spring extension hooks to the midpoint of the connector rod, the spring on the other end hooks to the cross member, look close, you will see a hole near the edge. | | |
#44625 03/25/2003 1:12 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Thanks Brian - I'll look closer for the spring attachment point this evening, maybe the POR-15 gooped over it..I didn't realize the manual is for a '54. | | |
