1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44598 05/28/2004 2:54 AM | Joined: Apr 2004 Posts: 84 Member | | Member Joined: Apr 2004 Posts: 84 | Should oil presuure gauge on a 216 engine fluctaute with engine rpm? I.E. the higher the rpm the higher the reading.....It's the low pressure readings I'm concerned about. | | |
#44599 05/28/2004 3:16 AM | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I am no mechanic, but it would seem all engines would pretty much be the same. My 350 does the same thing. Higher RPM's drives the oil pump faster, therefore, higher oil pressure. Someone here will correct me if I am wrong. | | |
#44600 05/28/2004 4:02 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | yes you are correct all thou a a extra low oil pressure reading at ideal may be sign of: to thin oil, weak oil pump, bad cam bearings etc if you here a light nockin or tick sound after driving it hard and coming to a stop at a idel it might be A bearing most likely its nothing inportent | | |
#44601 05/28/2004 5:53 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Hello-
My 1937 216 when cold will hit 30psi, once the oil warms up and driving at 35 mph around 15psi, 3psi at idle on a hot day. I have put over 12k on that engine in the last 5 years. No problems. I run straight 30 weight. I have also used 20W50 in that engine. Remember you also have dippers on the rods. Not all is lubricated with the pump. My Uncle bought the truck new and said he only had the valves done once, no lower end work. I have never rebuilt it. Just resealed it. 63k on the engine and going strong.
Brent | | |
#44602 05/28/2004 4:17 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | It is normal for the oil ressure gauge in a 216 to rest on the peg @ idle , this is a very low pressure oiling system that requieres volume , not pressure to keep things in proper order so as long as the needle comes off the peg as you come off the stop line , all is well .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#44603 05/28/2004 10:19 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The oil pressure gauge reads off the rocker feed line. This is a low pressure feed. The pump flows HEAPS of oil. | | |
#44604 05/30/2004 12:09 PM | Joined: Apr 2004 Posts: 84 Member | | Member Joined: Apr 2004 Posts: 84 | Thanks everyone. Now I know she won't blow up! | | |
