2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Hooray, Hooray.
I have the 3 speed overdrive, the switches and relay. I also have the wiring diagram (many thanks to squeeze). I believe I can put a wiring harness together with the correct gage wire.
The latest question concerns the resistors. What kind of resistors are located at the starter motor and inline with the power source. The diagram shows power coming from the IGN 1 and IGN 2 poles of the ignition switch and connecting to both sides of the resistor. This line has a fuse holder with a 9 amp fuse.
That's confusing. Any help?
Also, a question about the resistor on the generator for the radio. What kind of resistor is that?
TIA
Dennis
Dennis - the resistor on the wiring diagram is the ignition resistor that's mounted on the firewall - all ya need is to tap off the brown end of that resistor w/ a fuse holder and bob's yer uncle - or was it ralph? grin
coil, starter, start sw and gauges don't change from what they are w/o the OD - notice the bottom left corner {OD relay} goes to "BAT" which just means hot/power; other side goes to {kickdown sw}, which goes to ign2 by way of coil, and to the trans {solenoid}
ties it all together - keep it simple! grin
oh yeah - don't know about the resistor for the radio, but it's to keep ign from makin static - actually now that I think of it, isn't it a capacitor?
Oh, btw, the purpose of wiring the overdrive to the ignition is so that the solenoid can short it out when it needs to kick down, to let it shift. This is normal and you may notice it while driving.
Paint & Body Shop moderator
I have a Muncie overdrive (three speed) that I plan to install in my 62 1/2 ton chevy truck. Two questions-where can I get a gasket set for it and can't I hook up a switch to manually engage the overdrive since I don't have all the wiring to connect to the carb? Someone said that I will need a cable to go in and out of one part of the unit and a simple switch on the dash to engage the selonoid? Any suggestions? The trans came out of a Studebaker .
Squeeze & 4onthefloor - once again, thanks for the information. It looks like I got everything electronic and will get it all hooked up. As soon as I get the time. All I need now is a cable.
Emdabbs - you can get the overdrive gaskets package from Heavy Chevy (Arkansas). $4.95.
Thanks again to all.
Dennis
