1 members (baldeagle),
109
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 11 New Guy | | New Guy Joined: Apr 2007 Posts: 11 | Does anyone know of a source for a 3 speed manual floor shift? I have a 1st series truck and have no luck finding one. I can find one for a 2nd series (54 and later).
Thanks Larry WIlke 1952GMC 101 1959 Edsel Ranger 2DR and 1956 Dodge Lancer Custom Royal (in progress)
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i used a hurst on my truck. i know it is a 54 but i would think it would work on yours.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have a transmission that is a 3 speed floor shift. I have used it in several vehicles, and behind several engines, the biggest was built up GMC 270. I never had any of the shifting problems that plagued the column shifters. I think it was from a pickup truck back in the '30's, but I have adapted gears from a later model trans i.e. roller bearing cluster gear, synchromesh, etc. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Outside of the usual cyber swap meets, you might try Novak .
Dave
| | | | | Joined: Apr 2007 Posts: 11 New Guy | | New Guy Joined: Apr 2007 Posts: 11 | I already tried Husrt with no luck for a first series. I'm waiting for Novak to get back to me. I can't believe I'm the first person that wanted to install a 3 speed shifter on the floor for a 1st series GMC. I tried Lokar, but they do not get back to me after several phone calls. The 3 on the tree works fine, I just want a floor shift since I'm driving this to Arizona this fall from the UP of Michigan. 1952GMC 101 1959 Edsel Ranger 2DR and 1956 Dodge Lancer Custom Royal (in progress)
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | We butchered up a lot of floorboards back in the 60's installing floor shifters. Just about any shifter can be adapted to your trans, it's just a matter of getting the shift rods and the bellcranks positioned right, plus bracketing the shifter to the tailshaft of the transmission. Get a big hammer, a hacksaw, a torch, a welder, and a pile of scrap steel and make it work. It will be butt-ugly and unreliable, but that's exactly what we ended up with back when we were know-it-all teenagers! Jerry
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Hurst made a shifter for these in the 50's and 60's that was a bolt on. I have managed to nab a couple of them NOS on eBay. | | | | | Joined: Apr 2007 Posts: 11 New Guy | | New Guy Joined: Apr 2007 Posts: 11 | When I talked to Hurst they said that they do not have anything that will fit. If you have one please let me know the costs and how to contact you.
Thanks Larry Wilke 1952GMC 101 1959 Edsel Ranger 2DR and 1956 Dodge Lancer Custom Royal (in progress)
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Larry,
The shifter unit itself is generic and should fit anything and everything. The thing that makes it year or model specific are the mounting brackets. Jerry pointed this out above.
If you find any shifter assembly, it can be made to work perfectly by fabricating your own brackets.
If you don't have the resources to do any fabrication then you of course will have to find a ready made package. Even one close in year/application would probably be a drop in...almost!
Stuart
