3 members (baldeagle, 2 invisible),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,535 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | Help needed. I'm working on a 64 C-10 Stepside, it came with no engine, tranny or driveshaft. I rescued a good drivline out of a 63 C-10 but the mounting for the center carrier bearing is different from the mounting holes/position on the 64. If I buy a new carrier bearing for the 64, will the 63 driveshaft fit in the new carrier bearing? Appreciate any help.
PBO | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Check out Rockauto.comThey show pictures of the different carrier bearings and size listings for both trucks. Coincedentally both 63 and 64 show the same 5 numbers of the various center bearings. Jeff | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Hey, your in Tahuya! Cool. Nice to see more Washington folks here! You'll find all the truck info you could ever need here. Welcome to the 'Bolt.
Take it easy, Jeff | | | | | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | Jeff, thanks for the info, I'll check it out. Yep, I'm up here in Gods Country, been here about 17 years. I'm working on the 64 Stepside and will soon be working on my 52 3100 - are you local?
Jim | | | | | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | Jeff, I checked out ROCKAUTO and I can get the diameter of the shaft I have. It looks like what I need to start with is the "bracket" that carries/retains that center bearing. Any ideas? Thanks,
Jim | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I havent dealt with a newer setup with the carrier bearing. I think most of these are now made as a replacement with the bracket as a one piece setup. It may be worth measuring the cross member to see what the spacing is on the bolt holes.
If you cant find that info on Rockauto you can always take those numbers down to Napa or wherever and have them get the parts so you can measure them yourself and see what should fit. I do that all the time, ordering several parts to find the one I need.
Im up on the north end of the Peninsula in the Kingston/Hansville area. We're just across the ferry from Edmonds. Ive lived here my whole life and I love it and I cant imagine a nicer place.
Good luck!
Jeff | | | | | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | Jeff, thanks. It's been awhile since I had the time to work on this "stuff", takes awhile to get up to speed.
Nice area up there. Jim | | |
