8 members (mason86, Ol'55, klhansen, Hotrod Lincoln, 32Fordpuchoptop, Ponchogl, Phak1, 1 invisible),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | i have a 1951 pu and the fuel gauge does not work. I purchased a new gauge from Jimmy Carter. Is it difficut to install? | | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | It's not to bad,I'v had mine out a few times, almost need to stand on your head to get at it though.Just one thing,don't brake the tube for the tempature gauge. You might not need to replace it though,I'm working on the same thing now,and from what I'v researched there are a lot of things that will keep it from working.Does your gauge go to full with the key on or do nothing? | | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Disconnect the line that goes from the gauge to the sender. Then turn the key on. If the gauge pegs to full, it is OK. If the gauge does nothing, it is most likely bad.
| | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | the truck came with a gas gauge under the dash so it has been disconnected. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | If it is disconnected, it won't do anything at all. It will have no power, and no grounding from the sending unit either, but if you have connected it, right, it should do something. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Since it's had an aftermarket guage added (most likely because the original quit working) there is a good chance you'll need a new sending unit as well. The aftermarket one may not be calibrated properly for use with the OE style gauge.
Bill Burmeister | | |
