2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#443676 08/20/2008 3:09 PM
Luckly it was just pulling out of the garage. I don't know and can't figure out what has happened. It is an aftermarket booster,master cylinder and pedal assembly and they have worked for the past year and a half fine.
Here's my check list:
fuild- fine
leaks- none
booster- holding vacum
bleed master cylinder- done, fuild moves, no air
pedal goes to floor, no brakes- yes right away!!!!
This is a disc/drum set-up so I have the proporitioning valve in place.(could have gone bad, it is a used one??)
Any ideas please feel free to help me out on this one.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
The proportioning valve should have shut off the flow to the front or rear depending on where the failure is so you should not loose everything. I have not seen a proportioning valve cause a total loss of braking. I would suspect an internal failure in the master cylinder. You said you were able to get pressure out of it but I would take a closer look at it.
Fred
If it is an after market MC I would think it must have two cylinders. It is scary to think something would cause everything to quit and leave you with no pedal. That would change the term "parking brake" to EMERGENCY BRAKE". big_eek
~Jim
It sounds like the MC is bypassing fluid before enough pressure is reached to activate the brakes. The whole idea of a dual system is so there is not a catastrophic loss of brakes. Have you tried plugging the MC ports to see if you have a hard pedal?
Thanks guys for the help but I think I get the "DUH" award for the week. I forgot about one thing I did. I wanted to raise the pedal off the floor alittle more so I unscrewed the rod under the dash about 15 turns or so. Well what I did was pull it away from the booster diaphragm and thus no brakes at all. The rod was not reaching the MC enough to apply the brakes just enough to bleed it to appear that it was working alright. I fixed the rod and got it longer and where I want it and now have plenty of brakes. Even took my daughter out for a ride tonite
Thanks again
David
Just a firefighter,
'46 1/2 T Panel
The Official DUH AWARD Committee has accepted your nomination and you will be receiving your award in the mail shortly. Congratulations.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Sound's similar to what I did but with the motor.Had 4/8 plug wires reversed.tried for an hour to figure out what happend.my btother show's up (who is NOT a mechanic at all)or so I thought.Found the problem in less than a minute!GRRRRR
We've all been there! eeeek
~Jim
Czechman, your reply made me laugh out loud...scared the cat.
