4 members (MickeyP, Ole49GMC, Tronman, Peggy M), 83 guests, and 1 robot.
Topics128,043
Posts1,055,610
#444109 08/21/2008 6:00 PM
I tried the search function but came away empty handed. Maybe I can't read the tutorial.
Anyway I'm looking for the tapered rubber piece that mounts between the door and the tail light assembly. Can't seem to find one in the catalogs. Anyone know of a source other than the swap meet? I will post there as well.
Robert
Robert,
Presumably, you are referring to a 47-55 panel body rear-door light:
http://www.classicparts.com/1947-56--Panel-T_L-to-Door-Pad-each/productinfo/49%2D971/
Tim
Robert,
Tim gave you the classicparts web site. I'm not at home to double check, but I think you'll also find them at bowtiebits. In any case they run about $45 where ever you find them. Good luck with your panel.
Bettyann
