9 members (Tronman, tclederman, Bill Hanlon, Otto Skorzeny, Hotrod Lincoln, carbking, 49choptop, Guitplayer, John L.),
145
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 36 New Guy | | New Guy Joined: Aug 2007 Posts: 36 | I tried the search function but came away empty handed. Maybe I can't read the tutorial.
Anyway I'm looking for the tapered rubber piece that mounts between the door and the tail light assembly. Can't seem to find one in the catalogs. Anyone know of a source other than the swap meet? I will post there as well.
Robert | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Robert,
Presumably, you are referring to a 47-55 panel body rear-door light:
http://www.classicparts.com/1947-56--Panel-T_L-to-Door-Pad-each/productinfo/49%2D971/
Tim | | | | | Joined: Sep 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 55 | Robert, Tim gave you the classicparts web site. I'm not at home to double check, but I think you'll also find them at bowtiebits. In any case they run about $45 where ever you find them. Good luck with your panel. Bettyann | | |
