| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44408 02/26/2004 11:59 PM | Joined: Feb 2004 Posts: 11 New Guy | | New Guy Joined: Feb 2004 Posts: 11 | I have a 1949 3100 with a 216 with 3 on the tree. I have a 283 that I beleive is out of an early 60's Bel Air. I'm wondering if anybody out there have done this before? And what problems that might arise from such a swap. Any info would be greatly appreciated. | | |
#44409 02/27/2004 1:01 AM | Joined: Mar 2003 Posts: 23 Junior Member | | Junior Member Joined: Mar 2003 Posts: 23 | Hi there, I swapped a 283 in place of a 235 in my '62 Belair. It was very easy & I'm pleased with results. Your truck will be a little different. I'm sure others will chime in with things I missed, but I'll give you the basics. 1. Need to make/buy crossmember for motormounts. 2. Need correct bellhousing for smallblock. They are cheap & easy to find. 3. Clutch pivot from block to frame should have removable extension? My '62 Belair had this. 4. Check radiator clearance. Probably need a better rad anyway. 5. Is your truck still 6volt? Your V8 will need 12V. 6. New exhaust. 7. Modify throttle linkage.
Good luck on the swap. Scott
Scooter
I am a total control freak. I shift for myself. No auto's!
1948 1 ton 5 window w/235 1951 1.5 ton dump w/235 1966 3/4 fleetside w/283 1962 Bel Air 235 w/OD & one rusty,beat up,240K mile '82 Chevy 3/4 ton
