4 members (ShopRag, kades51, TUTS 59, dt235sd), 111 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#443648 08/20/2008 1:17 PM
TPB
Offline
i have a 1951 pu and the fuel gauge does not work. I purchased a new gauge from Jimmy Carter. Is it difficut to install?
TPB #443732 08/20/2008 5:56 PM
It's not to bad,I'v had mine out a few times, almost need to stand on your head to get at it though.Just one thing,don't brake the tube for the tempature gauge.
You might not need to replace it though,I'm working on the same thing now,and from what I'v researched there are a lot of things that will keep it from working.Does your gauge go to full with the key on or do nothing?
48 one ton #444959 08/23/2008 6:29 PM
TPB
Offline
nothing at all
TPB #444973 08/23/2008 7:16 PM
Disconnect the line that goes from the gauge to the sender. Then turn the key on. If the gauge pegs to full, it is OK. If the gauge does nothing, it is most likely bad.
tclederman #445301 08/24/2008 8:45 PM
TPB
Offline
the truck came with a gas gauge under the dash so it has been disconnected.
TPB #445316 08/24/2008 9:57 PM
jdl Offline
If it is disconnected, it won't do anything at all. It will have no power, and no grounding from the sending unit either, but if you have connected it, right, it should do something.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #445330 08/24/2008 10:50 PM
Since it's had an aftermarket guage added (most likely because the original quit working) there is a good chance you'll need a new sending unit as well. The aftermarket one may not be calibrated properly for use with the OE style gauge.
Bill Burmeister
