| | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I have a 66 fleetside and would like to determine what is the practical limit for wheels and tires other than stock. I have the factory hubs, etc. and am shopping for wheels and tires now. Of course I want good clearance and turning and I want them to bolt up to the original hubs. Can someone steer me in the right direction here? No pun intended. Thanks for any help. Gary Sova
GS
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Any good local tire shop that sells aftermarket rims should gladly offer to measure your truck and provide reccomendations and should be willing to guarantee they won't rub.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Thanks, That's what I needed to hear. I didn't want to get ripped off.
GS
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 31x10.50x15 would be about the largest with a stock truck without rubbing. Use a wheel speced for a '71-'87 solid axle 4x4 GM truck, 3 1/2" backspace. You will have to remove the rivets that hold the front drums to the hubs so that the wheels will fit flush.
Bill Burmeister | | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | You didn't mention if it is a K, or C, but i've got a 65 K10 fleetside, and I went with 33x12.5x15 on new procomp 1069 wheels. Got them for a steal at JC Whitney for $1300 delivered (yes that was mounted, balanced, and came with lugs and caps.). Got pictures of them them at my truck photo page if you want to see how they fit.  | | | | | Joined: Sep 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 49 | I went with 30 X 9.50 X 15 on my K10 'Burb. The truck had bigger tires when I got it. 31 X 10.5. They looked OK, but I decided to go with a smaller tire that would work a bit better in snow. Narrower is generally better in snow.
The new tires are Cooper Discoverer ATR on Pacer 107P Soft 5 Polished Aluminum Wheels. Out the door price, for 5 wheels and tires, was $1186.50. That was May of '07. The setup looks good on the truck. Tires are wide, but not too wide, for my taste.
Check out the wheels on the net. | | | | | Joined: Dec 2019 Posts: 451 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 451 | Had 39x15.5x15’s on my ‘63 fleet short box years ago, but it had a lift kit and don’t remember how much. Could park my porsche up to the windshield under it.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Sep 2009 Posts: 6,204 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,204 | Had 39x15.5x15’s on my ‘63 fleet short box years ago, but it had a lift kit and don’t remember how much. Could park my porsche up to the windshield under it. Larry - yours might exceed (by a lot - hahaha!!!) what Gary is going for.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
