2 members (cmayna, CuzzFuzz), 60 guests, and 7 robots.
Topics128,012
Posts1,055,320
Members48,419
#443451 08/20/2008 12:55 AM
When trying to remove a rear axle, I the bolt that holds the differential pin that must be removed to gain acces to the retaining rings holding the axle in place is broken(the bolt)
the bolt came out but the end of it that holds the pin in is broken and stuck. Any good ideas ? I plan ondrilling it out I guess.
gazim #443456 08/20/2008 1:01 AM
I take it that the threaded part came out, and the rest of the pin is stuck in the carrier. You might try a magnet if you can get one small enough or powerfull enough to pull it out. Try some light tapping on the case to help jar it loose.
Bill Burmeister
LONGBOX55 #443819 08/20/2008 10:57 PM
Well I got ther pin out with a lot of drilling. will have to address the new locking bolt in the near future. another problem has reared its ugly head. Will start a new topic on this one
gazim #443840 08/21/2008 12:01 AM
to bad you didnt have a ford 9 inch
Redryder pix
My Hotrod
