1 members (J Lucas), 98 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#44245 07/18/2002 11:10 AM
ki ora everyone hello i am having probs with the carb shes starts to back fire when shes getting warm i have cleaned the carb regasked her checked for leaks with ether i was thinking can a valve cause a backfire if its to tight? usually its fuel or electrics ive cleaned fuel a new filter a new condencer in the dizzy new points so if there is something ive missed or yous can think of something besides what ive tried i would greatly appreciate it 235cc rochester carb in a 46 pick/up also will a 55 diff fit straight in the rear of my 46 and spline fit? cheers pete
p j a
#44246 07/18/2002 12:10 PM
An over tight valve could cause backfireing. You should also check the timing and the spark advance parts.
if it dosen't need fixed, break it
