3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#44203 03/03/2004 7:43 AM
The cable on the drivers side hand brake is stuck on.
The truck wont move at all , I tried to rock it , and nothing.
I was looking at the cable while a friend pulled the lever back and forth..It moved only up to the coupler then stopped.
I pulled the tire to look in the drum, but do I need to remove all the boltd in the middle of the hub to get the drum off..[the truck is a 3/4 ton]
thanks
#44204 03/03/2004 2:13 PM
You might be able to turn the adjuster to backen off the shoes to get the drum off, if worse comes to worse you may have to cut the cable at the drum and punch the cable in to get the drum to release. I have tried to free up stuck brake cables in the past, only to have the stick again and loose my brakes to the brakes staying on and boiling the brake fluid, and then having no brakes, Not worth the cost.
#44205 03/03/2004 5:56 PM
Soak the cable housing with a good penetrating oil, such as Kroil or PB Blaster. Let it set for a few hours and soak it again. See if that lets the cable release. If not, follow Albert's advice.
Fred
52 3600
69 C-10
