1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#441491 08/14/2008 1:43 AM
I'm having a hard time finding a fuel sending unit to match up to my new gas gauge (for a 1950 3100) that's 12 volt I got from Jim Carter. Jim Carter says it's 32 ohm. The gas tank came from Yogi's but Yogi's people and Jim Carter's people can't seem to speak the same language. Brother's has a 32 ohm replacement unit but they're on backorder and will be 2-3 weeks. The unit (the top) is about 2 3/4 inches in diameter and has 5 screws in it.
Any help or advice would be hugely appreciated.
[email protected]
regmudd,
Your '50 came equipped with a 0-30 ohm sending unit that matched the fuel gauge. As you are discovering, these two items need to be compatible or your reading will be bogus.
30 ohm senders are distinctive to the old Chevrolet's. Most vendors have them and the float can be easily bent to function is different tanks. I'm not familiar with 'Yogi', but it doesn't sound like a reproduction style tank.
Stuart
atomarc #441590 08/14/2008 11:57 AM
correct
Old chevs had 0-30 ohm senders. Modern GM is 240-33.5 ohm, and Fords use 0-90 ohm.
the SAE standard fuel sender mounting pattern is the 5-bolt pattern and 2.75" in diameter
Scott
yes old chevys were 0-30 ohms a lot of newer gms are 0-90 alot of ford and chrysler are 70-10 ohms and there are others for universal types of fuel gauges...........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
It sounds like it must be a 0-30 ohm gauge from Jim Carter even though it's been upgraded to 12 volt? Where do I get the fuel sending unit to match it and I presume I tell them I want it to hook up to a 0-30 ohm gas gauge? Is that enough detail or will they want more info? And again, where can you get the fuel sending unit?
regmudd
regmudd,
The fuel gauge has been modified to work on a different volatge (12) but the resistance parameters are the same...0 to 30 ohms. Jim Carter has the matched sending units for the gauge as do many of the specialty suppliers. You just have to make sure it will fit into your 'Yogi' tank.
All the vendor has to know is that it's a sender out of an old Chevrolet truck...he should know it's a 0-30 unit.
You probably will not find something like this in a 'universal' configuration at your local auto part store. 0-90 is the common critter.
Stuart
Will the 0-90 ohm work or do you need one specifically for the 0-30?
regmudd
a 30 ohm gauge uses a 30 ohm sender, no substitute
Flxible #442567 08/17/2008 12:51 PM
What Bill said. gauges and senders must be paired / matched. No mixing of ranges
Scott
OK Where can you get one that will work? Jim Carter, as I understand, only has the ones that fit in the original gas tank. Brother's doesn't have them in stock so they're looking at 3-4 weeks. Yogi's doen't have them. Googling and checking the internet has not come up with anything.
Help.
REgmudd
regmudd #442859 08/18/2008 12:26 PM
