4 members (lumbersawyer, Hush, 2 invisible),
64
Mod | | | Forums66 Topics128,026 Posts1,055,407 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I'm having a hard time finding a fuel sending unit to match up to my new gas gauge (for a 1950 3100) that's 12 volt I got from Jim Carter. Jim Carter says it's 32 ohm. The gas tank came from Yogi's but Yogi's people and Jim Carter's people can't seem to speak the same language. Brother's has a 32 ohm replacement unit but they're on backorder and will be 2-3 weeks. The unit (the top) is about 2 3/4 inches in diameter and has 5 screws in it. Any help or advice would be hugely appreciated. [email protected] | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | regmudd,
Your '50 came equipped with a 0-30 ohm sending unit that matched the fuel gauge. As you are discovering, these two items need to be compatible or your reading will be bogus.
30 ohm senders are distinctive to the old Chevrolet's. Most vendors have them and the float can be easily bent to function is different tanks. I'm not familiar with 'Yogi', but it doesn't sound like a reproduction style tank.
Stuart | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | correct
Old chevs had 0-30 ohm senders. Modern GM is 240-33.5 ohm, and Fords use 0-90 ohm.
the SAE standard fuel sender mounting pattern is the 5-bolt pattern and 2.75" in diameter
Scott
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | yes old chevys were 0-30 ohms a lot of newer gms are 0-90 alot of ford and chrysler are 70-10 ohms and there are others for universal types of fuel gauges...........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | It sounds like it must be a 0-30 ohm gauge from Jim Carter even though it's been upgraded to 12 volt? Where do I get the fuel sending unit to match it and I presume I tell them I want it to hook up to a 0-30 ohm gas gauge? Is that enough detail or will they want more info? And again, where can you get the fuel sending unit? Thanks, regmudd | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | regmudd,
The fuel gauge has been modified to work on a different volatge (12) but the resistance parameters are the same...0 to 30 ohms. Jim Carter has the matched sending units for the gauge as do many of the specialty suppliers. You just have to make sure it will fit into your 'Yogi' tank.
All the vendor has to know is that it's a sender out of an old Chevrolet truck...he should know it's a 0-30 unit.
You probably will not find something like this in a 'universal' configuration at your local auto part store. 0-90 is the common critter.
Stuart | | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | Will the 0-90 ohm work or do you need one specifically for the 0-30? Thanks, regmudd | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 30 ohm gauge uses a 30 ohm sender, no substitute
Bill | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | What Bill said. gauges and senders must be paired / matched. No mixing of ranges
Scott
| | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | OK Where can you get one that will work? Jim Carter, as I understand, only has the ones that fit in the original gas tank. Brother's doesn't have them in stock so they're looking at 3-4 weeks. Yogi's doen't have them. Googling and checking the internet has not come up with anything.
Help.
REgmudd
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | | | |
