4 members (Gdads51, Bill Hanlon, 3B, Otto Skorzeny), 166 guests, and 3 robots.
Topics128,110
Posts1,056,246
Members48,437
Removing radiator out of 64 C-10. Found 2 lines running back to tranny from radiator. Connect into passenger side of tranny. About 5/16 line. Checked Shop Manual found nothing. Must of been addded by PO. Any ideas? my thiught is it must be used to cool tranny. Just a rookie, still learning
1964 Chevy C-10
Yep, that's what its for. It runs tranny fluid through a little oil cooler inside the radiator.
Paint & Body Shop moderator
Josiah, you got me confused. You said it's running trans fluid through an oil cooler "INSIDE" the radiator? I would think it's running radiator water around an oil cooler inside the tranny. I either need to have this radiator re-cored or buy a new one. If I buy a new one I will have to tap hole is it for the trans lines. Thanks
1964 Chevy C-10
Anonymous
Unregistered
Anonymous
Unregistered
4spd has it right. Transmission fluid comes from the tranny, through a heat exchanger inside the radiator back to the tranny. Alternately, you could buy a transmission cooler core and mount in front of your radiator for better cooling.
