| | | Forums66 Topics128,077 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44128 08/13/2003 6:24 PM | Joined: Aug 2003 Posts: 11 Member | | Member Joined: Aug 2003 Posts: 11 | Removing radiator out of 64 C-10. Found 2 lines running back to tranny from radiator. Connect into passenger side of tranny. About 5/16 line. Checked Shop Manual found nothing. Must of been addded by PO. Any ideas? my thiught is it must be used to cool tranny. Just a rookie, still learning
1964 Chevy C-10
#44129 08/13/2003 6:59 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yep, that's what its for. It runs tranny fluid through a little oil cooler inside the radiator.
#44130 08/13/2003 7:35 PM | Joined: Aug 2003 Posts: 11 Member | | Member Joined: Aug 2003 Posts: 11 | Josiah, you got me confused. You said it's running trans fluid through an oil cooler "INSIDE" the radiator? I would think it's running radiator water around an oil cooler inside the tranny. I either need to have this radiator re-cored or buy a new one. If I buy a new one I will have to tap hole is it for the trans lines. Thanks
1964 Chevy C-10
#44131 08/13/2003 8:02 PM | | Anonymous Unregistered | | Anonymous Unregistered | 4spd has it right. Transmission fluid comes from the tranny, through a heat exchanger inside the radiator back to the tranny. Alternately, you could buy a transmission cooler core and mount in front of your radiator for better cooling. | | |
